Thunderbolt or MSD >
Thunderbolt or MSD
Thunderbolt or MSD
Old 02-11-2015 | 08:16 AM
Default Thunderbolt or MSD
I blew an engine last summer and am having Dave Wesseldyke build me a couple of 540s out of my old HP500s. Should kick out around 600hp per side. I'm trying to figure out what to do about the ignition – whether to keep my existing thunderbolt or to go with MSD. I've heard strong opinions on every side of the issue, but am wondering what you guys think. If I go with MSD, am I going to run into lots of problems?
chris21hope is offline
Old 02-11-2015 | 08:24 AM
Daytona sensors. Hands down way better system than msd
Unlimited jd is offline
Old 02-11-2015 | 08:28 AM
ask dave and go with what he recommends.
mike tkach is offline
Old 02-11-2015 | 08:30 AM
I would use a stock GM Hei b4 I used MSD. MSD has left me sitting in the water. And not only that but I've had RF noise problems with MSD that was a nightmare figuring out.
Black Baja is offline
Old 02-11-2015 | 08:40 AM
Msd=suck
brian41 is offline
Old 02-11-2015 | 09:52 AM
Biggus's Avatar
Stick with the TB IV. If you need more initial timing, run the V6 module. Yes, MSD sucks.. and no need to further complicate a simple build.
Biggus is offline
Old 02-11-2015 | 12:52 PM
From: East Texas Waterfront- running errands if anyone asks
Does a Gen 4 Mercury ignition work in a Gen 5/6 application. If so, would you guys also stick with a Gen 4 Merc Mag ignition over a GM HEI or other?
Flightplan is offline
Old 02-11-2015 | 12:55 PM
MSD = my spark died
billy boats is offline
Old 02-11-2015 | 01:16 PM
Gen 4,5,6 can all use the same parts. I have 2 dist and v6 modules I'll let go fairly cheap.
Old 02-11-2015 | 07:13 PM
then you didn't have your connectors set up right.I posted a long time ago a diagram laying out the connectors.If and when the msd crapped out,switch a couple connectors and you were up and running on the HEI igntion.
Btw ,I ran my engines on a stock HEI and other on msd (560hp 454's) didn't notice any difference in performance.
sutphen 30 is offline
