B&M 250 refresh >
B&M 250 refresh
B&M 250 refresh
Old 02-14-2015 | 01:36 PM
Rookie's Avatar
Default B&M 250 refresh
Guys I need the low down on replacing the seals, bearings and teflon strips on my B&M 250's. I've read a few threads on the internet and it doesn't seem to be to be too complicated.
Anyone have a technical component breakdown sheet laying around.
Thanks,
Jason
Rookie is offline
Old 02-14-2015 | 05:33 PM
Jay, I know the rear bearings and seals are piece of cake, as is the snout bearing.
I may have the literature you seek. Ill dig thru some stuff tomorrow.
Are you finally gonna bolt those babies on???
MILD THUNDER is offline
Old 02-15-2015 | 01:38 PM
Rookie's Avatar
Maybe I'll just pack up some booze and head down to Chicago and see if they'll refresh themselves... lol
Rookie is offline
Old 02-15-2015 | 02:01 PM
It might be cheaper to just send them out to california. We like to drink around here!
Old 02-15-2015 | 02:20 PM
Rookie's Avatar
That's a relative term.I've probably bought less for more $$$.
Rookie is offline
Old 02-20-2015 | 06:37 PM
Rookie's Avatar
Were you able to find any literature? Do you know what bearing and seal part #'s?
No hurry, just curious.
Rookie is offline
Old 02-20-2015 | 08:44 PM
seal kit
http://www.jegs.com/i/Weiand/925/91167/10002/-1
seal kit without the base gasket and carb plate gasket
http://www.jegs.com/i/Weiand/925/9598/10002/-1
coupler
http://www.jegs.com/i/Weiand/925/7063/10002/-1
bearing set
http://www.jegs.com/i/Weiand/925/9592/10002/-1
Shaft /coupler /bearing
http://www.jegs.com/i/Weiand/925/155272/10002/-1
carb plate to blower case gasket
http://www.jegs.com/i/Weiand/925/91185/10002/-1
Shaft/coupler kit
Old 02-20-2015 | 08:54 PM
Sorry Rook, cant find the book I had with the breakdown of parts and diagrams.
The bearings themselves, I would buy from a bearing shop. From what I remember, they are nothing more than a very common industrial style bearing. 188 bucks for the bearing kit from jegs is alot. Prob get them from a bearing supply for way less than that.
As far as the blower to manifold mounting. They used an o ring setup on some, and some just a paper gasket. I can tell ya, forget the o ring setup. It flat out leaks. B&M actually had a bulletin on them, to basically go back to the regular gasket. The best gaskets I found are these from RBS superchargers. Good price and they are thick, and dont leak. The B&M 4 bolt mounting setup is not the best, compared to like a GMC blower.
http://www.rbssuperchargers.com/Prod...-0017&pID=7956
They also have the carb plate gasket, and much cheaper too.
http://www.rbssuperchargers.com/Prod...-0026&pID=7408
I see they also now have a bearing AND seal kit for them as well.
http://www.rbssuperchargers.com/Prod...0-038&pID=9131
Old 02-20-2015 | 10:29 PM
Rookie's Avatar
Sorry Rook, cant find the book I had with the breakdown of parts.
Lol, I'm sorry I can also use Google. I just thought you might have had the part#'s handy. RBS give you the bearing #'s on their site. Looks like SKF or Timken are about $6ea. I thought there might be some seal inside the ends. I have the intake and carb gaskets already. And I've already been warned to sealant, gasket sealant the intake and blower together. And that the Orings stuck... Literally!
Thanks once again,
Jason
Rookie is offline
Old 02-21-2015 | 05:04 PM
Rookie's Avatar
And so it begins...
Attached Thumbnails B&M 250 refresh-20150221_140728.jpg   B&M 250 refresh-20150221_141600.jpg   B&M 250 refresh-20150221_143045.jpg
Rookie is offline
