garage clean out, good stuff >
Old 02-16-2015 | 06:26 PM
Default garage clean out, good stuff
flush mount pop up cleats with alum backing plates for the 4 small ones not the big one. all
100ea for the small 125 for the big one.
gaffrig controls set up for twins with all neutral safety controls and trim switch on handle. can be reconfigured to work for a single
500
complete external duel ram hydraulic steering with the through transom fitting and inside lines.
its made my imco. They shine up perfect, took some armorall to the black lines and they polish up and are not cracked or split anywhere, they have been in my shed for at least 2 years.
1350
alum trim rings for gaffrig gauges
11 of the small ones
2 of the medium ones that were on the tachs
1 of the big ones that came off the spedo
they have been outside and are faded will need sandblast and power coat or paint.
5 bucks each
2 alum wide cleats power coated while, was factory rigged on a 2000 warlock 27 world class
25 bucks each
full set of gaffrig gauges for twins, they have been sitting outside in a boat with no cover for at least 3 years, some faces are bleached out some lenses are fogged over. all of these gauges were sold to me in working order. ive never used them, never seen them work. im selling them as unknown condition but should be working.
2 tach
1 speed
2 water temp with warning light
2 oil pressure with warning light
2 volt gauges
4 trim level gauges
1 fuel
id like to get 250 bucks for all of them.
pair of bbc cyl heads 10114156 these are the 118 cc combustion chamber oval port. the heads were disassembled spring tensions were checked valve stem seals replaced and valves were lapped in. after that about 10 hours run time so they are still fresh and ready for install.
250 for the pair
I have pictures of everything just couldn't get them on here. email me and I can send you them.
best way to contact me is email
[email protected]
Novaspd is offline
Old 02-16-2015 | 06:27 PM
why the F is it so hard to post pictures here!?!
I have pictures of everything just email me for them
Novaspd is offline
Old 02-16-2015 | 06:32 PM
Pics to [email protected]
Schiada 30 is offline
Old 02-16-2015 | 06:35 PM
F-2 Speedy's Avatar
Nova, you have to be a paid member to post pics, pay up and you'll receive these awesome koozie's you will cherish forever.........
F-2 Speedy is offline
Old 02-16-2015 | 06:40 PM
Pics of the steering please [email protected]
Baja226sport is offline
Old 02-16-2015 | 06:52 PM
Also to [email protected]
Pics of everything. Tks
Memberships are a good deal.
getrdunn is offline
Old 02-16-2015 | 10:15 PM
added more stuff
Novaspd is offline
Old 02-17-2015 | 01:17 AM
If you host pics on a photo sharing website, you can attach them. Otherwise you need a paying membership.
Griff is offline
Old 02-17-2015 | 06:48 AM
pictures of cleats please. [email protected]
1969pachanga is offline
Send me pics of small pop up cleats and gauges to [email protected] thanks
1989mach1 is offline
