565 cu.in. 800HP pump gas >
Old 02-17-2015 | 09:50 PM
Default 565 cu.in. 800HP pump gas
565 800 H.P. pump gas
Merlin 3 short deck block 4.600 bore
Eagle 4.25 crank internally balanced
Eagle 6.385 rods
Probe 10:1 pistons 2618 alloy
Speed pro file fit rings 1/16” & 3/16”
Michigan H series bearings
Fluidamper 8” balancer
SFI approved flexplate
Moroso blueprinted high volume oil pump
Moroso low profile oil pan w/kicked out sump 6 qt.
Jesel belt drive
Comp cams 4/7 swap mech roller w/iron gear 261/270 .734/.737 110 c/l
Isky EZX roller lifters w/bronze bushings ( no needle bearings )
AFR 335 cc CNC ported heads
Manley 2.300 11/32” severe duty valves
Manley 1.880 11/32” Inconel valves
Isky tool room gold stripe springs
Manley titanium retainers & 10 deg. locks
Manley 3/8” .080 pushrods
Jesel rockers
Pro-filer sniper Jr. intake manifold fully ported
Engine produced 805 h.p. @6300 rpms in dyno configuration
Has 2000 street miles
Highway driven to track ran 11.07 @124 3900 lb. chevelle in street trim
Leakdown tested at less than 10% in all cylinders
I have a Gil 14 qt. oil pan, flywheel and a nice pair of Imco angled valve covers to make it completely marine ready
In marine form it will no doubt make 725-750 HP and idle great with dry exhaust
914-262-1898 located in Mount Kisco NY $9500
Attached Thumbnails 565 cu.in. 800HP pump gas-img_0014.jpg   565 cu.in. 800HP pump gas-img_0012.jpg   565 cu.in. 800HP pump gas-img_0015.jpg
565 cu.in. 800HP pump gas-img_0017.jpg   565 cu.in. 800HP pump gas-img_0018.jpg   565 cu.in. 800HP pump gas-img_0019.jpg
Btrhd is offline
Old 02-17-2015 | 09:51 PM
Sorry for the twisted pics. Price is $9500
Btrhd is offline
Old 02-17-2015 | 09:52 PM
Did you have a price in mind or is this a make offer?
getrdunn is offline
