What are your top 3 repair problems with your boat that you would liked solved? >
Old 02-18-2015 | 03:26 PM
McManus Apache's Avatar
Default What are your top 3 repair problems with your boat that you would liked solved?
McManus Apache is offline
Old 02-18-2015 | 03:51 PM
#1. Glassdave took care of it last fall, I can now look at my bow without seeing a shadowy image, so now "stereo" moves to top of the list.
#2. I'd like my interior finished after its 3 month stay at the upholsterer.
#3. I'd like an impeller that lasts for years. Perhaps made of sheep parts. Hundreds of Scottish shepherds agree, that stuff lasts forever.
Speedracer29 is offline
Old 02-18-2015 | 03:57 PM
* Have it sold
* Someone Buy it
* No longer be mine
lol....j/k kind of. There is zero problems with my boat and all work or issues have been fixed or taken care of. So other than it needing a new home or me taking it out a few more times before it goes away, there is nothing that needs to be done.
Nate5.0 is offline
Old 02-18-2015 | 04:11 PM
1 MAIDEN AMERICA's Avatar
There's only one repair problem......COST!!!
Please fix that.
1 MAIDEN AMERICA is offline
Old 02-18-2015 | 04:19 PM
By solved I'm assuming it's a repair I have yet to diagnose and fix.
1. Correct the hard starting on these 454's using Weber carbs without going to another brand carb.
2. Replace bad port engine oil temp. gage, sensor is good. Tried for two seasons and cannot get to terminals to remove wires from gage and gage from panel. Need a second elbow in arm I guess.
3. Reconfigure trailer winch bracket. I know not boat but without trailer I have no boat.
Interceptor is offline
Old 02-18-2015 | 05:13 PM
waybomb's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Active Streak: 90 Days
1) put port engine back together
2) put starboard engine together
3) put center engine together
waybomb is offline
Old 02-18-2015 | 05:52 PM
1. Find new Stainless Marine exhaust systems for good price for both engines.
1. Find out why the shifters are very hard to operate on both drives.
3. Find electrical gremlin that causes drives to "stick" when buttons pressed intermittently.
Diamond Dave is offline
Old 02-18-2015 | 06:09 PM
Paint
Property I can build a barn on
Only 2 I'm not greedy.
tmmii is offline
Old 02-18-2015 | 08:14 PM
Your 1a, I will call it because you have 2 number 1's, is more than likely your detent balls in the out drives. Very simple to fix, pull the back plate off your out drives and clean and grease. They get corroded over time causing hard shifting.
Questofpower is offline
Old 02-18-2015 | 09:14 PM
Need stronger drives. Going to be running 600hp through my Bravo ones this summer after fresh builds, and am afraid I'm going to have issues....
chris21hope is offline
