Titan Surge Brake Actuator
Hydraulic Surge Disk/Drum Brake Actuator with Zinc plated finish for maximum corrosion protection.
Rated capacity: 20,000 lbs GVWR, 2,000 lbs tongue load. Mounting holes are on a 3" and 5" center front to back.
Recommended Use: For heavy or frequent-use applications, and for trailers pulled by trucks larger than standard pickups. Typical uses include but are not limited to industrial equipment trailers, agricultural spreaders, tank trailers and wagons, utility reel and pole trailers, and military ground support equipment.
Rated Capacity: 20,000 lbs
Ball Size: 2-5/16"
Brake Lock-Out: Yes
Frame Width: 3"
Price $165
Rick 847-502-2399
[ATTACH=CONFIG]537616[/ATTACH][ATTACH=CONFIG]537617[/ATTACH]
Ball Size: 2-5/16"
Brake Lock-Out: Yes
Frame Width: 3"
Price $165
Rick 847-502-2399
