Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Fiberglass Repair Shop Tools >
Old 02-27-2015 | 07:35 PM
Default Fiberglass Repair Shop Tools
Looking for some good recommendations on everyones favorite , or custom made tools . Like Sanders , Paint Guns , Grinders , Dust Collectors , Respirators and Eye Protection.
Too make the job of Fiberglass Repair Easier. I know all of us would like it to be easier!
dunnitagain is offline
Old 02-27-2015 | 07:52 PM
When it comes time to regel coat my bottom once I get my lift and save up the mone im doing it the easiest way there is and thats sending it to glassdave......
1989mach1 is offline
Old 02-27-2015 | 09:37 PM
Isolating tool with a good blade, the best blade I have found is the dremel carbide blade. A angle grinder with the roll lock sanding disc aka paddle wheels, they eat old tabbing off when redoing stringers and transom work. A good circle saw, you can set the depth of the blade to the transom thickness and cut a grid into the transom to remove each square. Tyvex suits with the hoodie made on. A 3M respirator with the full face cover/shield. A reciprocating saw. A good set of gasket scrapers, I have a nice set of snap-on scrapers I use to chisel out each of the pieces of the transom grid after cut with circle saw. A few beers to take the edge off of doing fiberglass work. And the best tool of all, OSO advise.
Brandonb_05 is offline
Old 02-28-2015 | 12:47 AM
Tyvek suits, 90 degree air diegrinder will rolllock 36 rit discs, 4 inch electric angle grinder with 36 grit flap discs, oscillating multi tool and a big shop vac with a good filter.
phragle is offline
Old 02-28-2015 | 07:55 AM
Keep the recommendations coming ,
What about Long boards ? Anybody like the 16" Airboards? I have 2 of the 3M 30" boards , what about air-powered 30" is there such a thing?
How about Abrasive Brands , Norton , 3M , Mirka , Pferd , what works good and what doesn't ?
Old 03-01-2015 | 07:42 AM
HF air plainer board word well for the money. Snap on DA orbitals 6". 90 degree angle grinder with 3m rollock disks. 3m makes nice hand file boards. Id like to see ideas for dust collectors. As for abrasives. I'm a fan of mirka. I've played around with 3m recently and for the added cost I don't find myself saying WOW! Norton is fine, not a huge fan tho.
Paint gun... SATA or nothing... Maybe iwata never sprayed one I hear they shoot nice tho
315duramax is offline
Old 03-01-2015 | 08:52 AM
315duramax, I'd like some ideas on Dust Collectors also , what are you pros that do this every day using? I have a friend in MO that has a large Body Shop and he uses a complete Dynabrade System in his shop.
He told me if the guys don't use it religiously he cans their ass! He said there is no reason to have a shop full of dust.
Old 03-02-2015 | 09:02 AM
Never heard any results of the dynabrade
Old 03-02-2015 | 09:31 AM
Buy bag filters (typically used for drywall dust) as you will plug a normal filter in short order.
JRider is offline
Old 03-02-2015 | 06:24 PM
spazboz's Avatar
Find an ambitious young person who doesn't know any better and pay them to help do the dirty work. That's one of the best tools you can buy!
spazboz is offline
