Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Ugly corner cockpit crack  appeared this weekend.....Advise on what should be done? >
Old 03-04-2015 | 03:29 PM
Default Ugly corner cockpit crack appeared this weekend.....Advise on what should be done?
https://www.dropbox.com/s/1srit2x33b...B1%5D.jpg?dl=0
https://www.dropbox.com/s/6k7crxtu71...B1%5D.jpg?dl=0
Boat is ten years old. Some minor hairline cracking in the other forward corner, but the rest of of the hull appears to be in great shape. Any advise appreciated...thank you.
FracBurner is offline
Old 03-04-2015 | 04:53 PM
glassdave's Avatar
Neno the mind boggler
what make and model is it? looks like some pretty standard flex/stress, many boats just have design problem areas that creep to the surface (literally)
looks fairly isolated but its is a bit of a technical repair, nothing difficult but does require a skilled hand. Do you plan on doing the repair yourself?
08 OPA High Points Champion
glassdave is offline
Old 03-04-2015 | 05:04 PM
Thanks for the response. It's a Baja Outlaw. No, I won't be doing the repair myself. Searching for a shop at the moment. I'm in the West Palm Beach, FL area.
Do you think it should be repaired immediately or can it wait a few months and a few more uses?
Old 03-04-2015 | 08:22 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Is this a 35' Outlaw?
US1 Fountain is offline
Old 03-04-2015 | 10:30 PM
glassdave's Avatar
you should be fine if you need to wait, in general its most likely superficial. Make sure whoever does the repair uses a good quality vinylester at the least.
Old 06-20-2015 | 05:34 PM
Dukedonzi's Avatar
What model Baja outlaw do you have?
Dukedonzi is offline
Old 06-27-2015 | 07:43 AM
Not a positive thing, but I can see that perhaps the laminate glass was not fully rolled onto the gelcoat in that area during the deck assembly layup, and a slight air pocket or area of weakness resulted.
A good fix would be to come at it from both sides, strengthening the back side and patching the top side. If it were my boat, I would not be to happy about it . . . shouldn't happen.
tpenfield is offline
Old 06-27-2015 | 08:34 AM
Tinkerer's Avatar
That looks to me like a structural flexing, Have you looked the boat over for other flexing that may have led to this failure. OR did you just have a VERY fun day jumping waves???
Tinkerer is offline
