What would cause 3 intake valves to leak on a diesel? >
Old 03-11-2015 | 01:45 PM
Default What would cause 3 intake valves to leak on a diesel?
Wondering what could cause multiple intake valves to not seal properly on a low hour Diesel
tommymonza is offline
Old 03-11-2015 | 01:52 PM
Full Force's Avatar
If it's like some diesels they don't put a seat into head, they just grind valve into casting and that to me is not a great idea, a buddy just realized this on a 6.4 Ford with international diesel, I could be wrong but sonething to look at...
Full Force is offline
Old 03-11-2015 | 01:57 PM
possible burnt valve
adk61 is offline
Old 03-11-2015 | 04:04 PM
What kind of diesel?
Black Baja is offline
Old 03-11-2015 | 05:19 PM
Detroit 12.7
Old 03-11-2015 | 05:20 PM
Yes more info what kind, application, and you said low hours, does that mean low factory hours or low hours after someone has been in it? How do you they are leaking?
Brandonb_05 is offline
Old 03-11-2015 | 05:24 PM
I have rebuilt a few of older Detroits mostly the two stroke Detroits 16v, 12v, 8v, and 6v
Old 03-11-2015 | 05:31 PM
If it is in a newer truck with emissions and has a egr system that is not properly working the egr issue could gum up the intake causing the valves not to seal. Just one possibility, really need more info.
Old 03-11-2015 | 05:41 PM
14 apache's Avatar
Detroit 12.7
Is this running now what is it in? Bad valve springs/broken out of adjustment?
14 apache is offline
Old 03-11-2015 | 05:43 PM
Sounds like 14 Apache needs to fabricate you up some piston cooling jets.
