Help Merc 700 Header Bolt Trouble
I am fresh out of explitives. I removed the headers on my 2007 700 SCI's to pressure check them. They were all good thank fully. The boat is a 32 DCB and there is very little access to the outboard header. I removed all the accessories from the 2,4,6,8 side. I got all the headers back on but something is going on with the lower bolt between 6 and 8. It will not start in the head. I loosened up the rest of the bolts so I could really jockey the header around with no success. Spent about 4 hours last night trying. I am bruised up and defeated. There is no corrosion anywhere. I wonder if anyone else has experienced this or has an idea how to get it done? Thanks
remove header and install a piece of all thread into the problem holes, hang headers on the all thread install nuts on all thread to hold header then install the other bolts snug. remove all thread and replace with bolts 1 at a time. that should solve the problem. If you double nut the all thread it should remove quite easily.
good luck
good luck
good luck
good luck
