1st boat need advice on purchase 1988 scarab 28ft >
Old 03-12-2015 | 04:30 PM
Default 1st boat need advice on purchase 1988 scarab 28ft
Hello forum! I'm Tommy I'm from Orange County Ny. I'm getting into this hobby for the 1st time. I'm very close to a purchase and just wanted some input as I know nothing about boats. I have a lot of knowledge on cars but I do not do my own work.
The boat that I'm looking at is a 1988 28ft scarab with a 496 and bravo 1 drive. I'm worried about just buying a lemon. Is there anything I can do to inspect this boat my self? Things to look out for? The guy claims the motor was rebuilt with only 8 hours on it. It looks ok from the pictures. I'm going hear it run before I buy it. But I just don't know what the hell I'm getting into. I just spoke to a boat broker by phone and he said I have to worry about rotted wood. Anything I could do to inspect that? I'm going to be using this boat on the Hudson in Newburgh Ny area. Speed is not what I'm after. I'm more after the look and a loud v8.
He is firm at 11,500
Any input would be appreciated.
Thank you
Tommycars845 is offline
Old 03-12-2015 | 04:55 PM
if you do not know where to start, hire a reputable surveyor. Wellcraft scarabs are good boats BUT, as was mentioned to you have a reputation for wet/rotted transoms and stringers. pretty much ANY older boat runs this risk, If its bad it could easily cost you haf of what you paid for the boat to get fixed.
phragle is offline
Old 03-12-2015 | 08:51 PM
You can find something more recent for a few dollars more...
msher44 is offline
Old 03-12-2015 | 11:11 PM
cigboat1's Avatar
Phragle and Msher are both right on the money with those answers .Doesn't matter what boat you look at spend the dollars to get the boat surveyed before you lay down the big money and for a few thousand more you can pick a twin 30 or possibly a 31 ...Take your time and don't buy the first thing you see and take someone who knows boats with you when you look.Good luck Jim
Good example is on offshore only :1994 29 scarab with twin 350,s rebuilt ,reworked and reupholstered. the guy is asking 17500,take a look and make him an offer ---- Much better buy !!offer him 15000 and he would probably take it.....fore four thousand more you have a much better boat
cigboat1 is offline
Old 03-13-2015 | 07:44 AM
For a first time boat owner a 27 or 28 would be perfect to start with. Its not to big where u will be over welled with the size and will be big enough to handle the river and even the lake if you go. A survey is the best way to go but if u want to do it your self take a hammer and tap around on the wood on the transom and stringers u will be Abel to here the difference between good and bad wood. U can always get better for more money but like u told my brother for your first boat spend what you wont get mad about. If you get some dock rash learning or bump something and chip the jel u and be like oops but the more you spend then it turns into omg with the f just happened lol. Buy cheep save and learn then in three years sell and move up. By then you might be looking to go bigger anyways.
1989mach1 is offline
Old 04-11-2015 | 02:07 PM
hello,,,as everyone has mentioned ..GET A GOOD SURVEY!!!!!!!!!!!!!.....
also......just cause the moisture is only 15 percent...which is good....it could all be dry rotted inside,,,as mine was or is.....
u can do the sounding test,,,but must have a ear for what u are listening for.....
i will be doing a posting...following the process of replacing my transom and main stringer.
as mentioned by others...good stringer wood is going to give u a solid ring....rotted or wet is going to be a dull sound..
sort of hard to desribe the sounds.....
good luck......
a good surveyor could save u thousands,,,ask me i know
flashgordon is offline
