Mark IV heads on a Gen V
Anyone ever do this? I've read on-line just as many people saying it can be done with gaskets as just as many saying it shouldn't be done because of water issue the special gaskets are supposed to solve. Got this pretty stock gen V 454 and a set of 049 heads just sitting on a shelf looking for a home. It already has a (oval port) edelbrock airgap on it and being able to keep it saves a bunch of money.
drop heads on block with no gaskets. reach under heads and scribe a line along block edge. flip heads over. now you can see how much metal you have between water ports and cam valley. some are ok, some a little too close to the edge...literally. i have a set of high-time L29 heads. were on some kind of industrial motor. need 16 guides and valve job. $100. an hour north of you.
As for your heads. The only reason I'm thinking about doing it is because I have the heads sitting on a shelf that need nothing. Cost is a real issue with this project. If I cant do it off the shelf (beside gaskets) it's not really worth doing.
the heads on it are still peanuts. if you are gonna pass on it let me know. one i was gonna redo for this summer is .010 over with a bad crank. if i wreck a piston pressing the rod off i gotta rebore...yeah, these L29 spares i have need about 400 bucks in guide and valve job...but as lil red was saying, it rarely does not work.
