How do I purge air from heat exchanger on 496 mag? >
Old 03-17-2015 | 06:29 PM
SunsationalMate's Avatar
Question How do I purge air from heat exchanger on 496 mag?
After replacing the thermostat on a 496 Mag, specifically how do I add antifreeze and completely purge air out of the heat exchanger before starting the engine?
SunsationalMate is offline
Old 03-17-2015 | 06:35 PM
It will do it on it's own there is a hose on top that goes back to the reservoir
dennis r is offline
Old 03-17-2015 | 07:45 PM
+1
Keith Atlanta is offline
Old 03-18-2015 | 01:46 PM
You will hafta run engine and watch level and top off.
dereknkathy is offline
Old 03-18-2015 | 04:07 PM
Fill cooling system thru reservoir to full line.
Start engine. Run at idle until normal op temp s reached. Keep an eye on temp gaugehen doing this. Merc states front of engine should be higher than rear to aid in bleeding air and only ran at idle. As air is dispersed from the system you may have to add additional top off coolant to the system after the initial fireup.
Ryan00TJ is offline
Old 03-19-2015 | 04:15 PM
Thanks for all replies. Appreciated.
Old 03-20-2015 | 12:11 PM
I'm assuming this same process works on any merc closed cooling system?
ivanfuego is offline
