wix oil filters >
wix oil filters
wix oil filters
Old 03-21-2015 | 12:23 PM
35fountain's Avatar
Default wix oil filters
I have been using the Wix 51060R. It says for racing applications only. What exactly does that mean?. I noticed on the Wix 51060 standard filter everything is the same accept the Fl;ow Rate GPM. The 51060 has a flow rate of 9-11 GPM and the 51060R has a rating of 28 GPM. Is that the only difference.? How much oil does my engine pump? It only holds 8 quarts. Wouldn't a standard Wix 51060 be ok?
Just wondering
35fountain is offline
Old 03-21-2015 | 12:37 PM
R flows more because it lets bigger partcles by,size that Apollard can see w/ the naked eye.
and the non R will be fine for your engine.
sutphen 30 is offline
Old 03-21-2015 | 04:00 PM
35fountain's Avatar
Thanks, I just order a case of them
Old 03-22-2015 | 09:15 AM
The NAPA gold is the same wix non racing filter...easier to find around here
ezstriper is offline
Old 03-22-2015 | 09:31 AM
35fountain's Avatar
Just got a case of 12 for 43.44
http://www.discountfleetsupply.com/wix51060.html
Old 03-25-2015 | 02:50 PM
CIG3's Avatar
If you want more capacity you can run 51794 which is the same filter but taller (2 quarts).
With stock power the non-R filter is more than fine. With that flow rate you are filtering your oil approx. 2x per minute with a 5 quart pan.
CIG3 is offline
Old 03-25-2015 | 03:16 PM
dcb
Carquest carries the Wix racing filters.
dcb is offline
Old 03-25-2015 | 04:59 PM
Would the R filters be better for the 500efi's. Looking to change to them this year from the merc ones
1989mach1 is offline
Old 03-26-2015 | 06:57 AM
CIG3's Avatar
You will be fine with the Non-"R" filter on your 500HP. Better filtering and more than adequate flow
CIG3 is offline
Old 03-26-2015 | 07:34 AM
Ok thanks
