Auto meter
Old 03-24-2015 | 07:52 PM
Default Auto meter
Has anyone installed the new gps speedo from auto meter. If so how do you like it. My gps speedo battery died and know they do not fix any longer. Thanks
baja27 is offline
Old 03-25-2015 | 12:32 PM
97FASTech's Avatar
Veteran: Army
Just had it out on Sunday, so far so good. This is the multi function one.
97FASTech is offline
Old 03-25-2015 | 01:27 PM
vintage chromoly's Avatar
Where and how did you mount your GPS pickup? Is it concealed?
vintage chromoly is offline
Old 03-25-2015 | 04:08 PM
If you have an Livorsi old "puck" style battery powered antenna you can order the new style powered antenna and mount it anywhere including under the dash. I replaced all mine last year to include the back seat ones which are mounted in the back of the front seats and I put the antenna in the foam of the seat and it worked great. Super easy to hook up comes with plenty of wire to mount anywhere with the terminals pre installed. No brainer.
Don Johnson is offline
Old 03-26-2015 | 09:40 AM
97FASTech's Avatar
Veteran: Army
Had it installed, never looked for the ant. Must be hidden under dash, because I did not see it anywhere.
