Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Using West Systems. how much to grind old fiberglass? >
Old 03-25-2015 | 02:03 AM
Default Using West Systems. how much to grind old fiberglass?
Using West Systems. how much to grind old fiberglass? If I am grinding roving do you make it perfectly flat with 80 grit? Anyone use the Norton wire wheel?
cyrus77 is offline
Old 03-25-2015 | 05:41 AM
Is it an epoxy boat to begin with??
phragle is offline
Old 03-25-2015 | 11:53 AM
No not expoxy.
cyrus77 is offline
Old 03-25-2015 | 12:14 PM
Any special reason your using west instead if say VE?
phragle is offline
Old 03-25-2015 | 01:57 PM
No. I just know of WS. I am grinding now and want to get the maximum adhesion, but no one has any pictures on the internet of grinding Glass.
cyrus77 is offline
Old 03-25-2015 | 02:48 PM
What are you doing exactly?
Unlimited jd is offline
Old 03-25-2015 | 04:52 PM
glassdave's Avatar
Neno the mind boggler
maximum adhesion is with 36 grit for a purely physical bond, or any other bond really. Epoxy rely's almost completely on a mechanical bond so the area must be 100% prepped, that means a thorough sanding and grinding. if it is partially sanded and there are even small areas between the sand scratches even that will decrease bond by whatever percentage is not sanded. I do prefer vinylester (still an epoxy in a styrene matrix) over a straight up epoxy though. A good VE gets ya great physicals at a fraction of the cost and will be more then most will ever need.
08 OPA High Points Champion
glassdave is offline
Old 04-29-2015 | 07:54 PM
Dave, I followed all the rules when I redid my bilge but I do have a question on methodology. Why is it still necessary to sand/grind the existing fiberglass only to adhere new fiberglass to it? I understand if it's covered with gel or paint, the glass needs to be exposed but I mean when it's already bare glass all inductions given still say to grind it. Couldn't you just wipe clean and laminate the new glass?
ramos45 is offline
Old 04-29-2015 | 08:19 PM
grinding gives it a good clean tooth
phragle is offline
Old 04-30-2015 | 01:38 AM
Understood, thank you.
ramos45 is offline
