Mercury Racing 525efi/ Blown up botttom end or stock in need of rebuild
I am looking for a stock Mercury 525efi. Prefer a worn out or bad bottom end. With or without exhaust is fine. Needs to have full dress with heat exchanger and factory ignition! I will consider a good running motor if the price is right. I have 2 full Bottom ends and a good set of exhaust, that's why I would prefer bad motor. I would also consider buying the whole motor minus the rotating bottom end!
Please call if you have one you want to sell. 239-443-8233
Still looking for a stock Mercury 525efi. Prefer a worn out or bad bottom end. With or without exhaust is fine. Needs to have full dress with heat exchanger and factory ignition! I will consider a good running motor if the price is right. I have 2 full Bottom ends and a good set of exhaust, that's why I would prefer bad motor. I would also consider buying the whole motor minus the rotating bottom end!
Cole one, they currently are all over the board. if you have your old base engine it can be exchanged for a rebuilt engine for $12-20,000. I found a pair with low hours, 2007, for $18000 each, but he does not want to sell separately.
I have a 2005 525 EFI complete with headers with 100 total hours,used in both fresh and salt water ,super clean located in NJ $18.500 Anymore info you need let me know or give me a call. Thanks Howard. 609 868 1875
