Mercury 200 or 225 Optimax 2 Stroke or 200 Verado 4cyl 20" shaft Smartcraft DTS >
Old 04-01-2015 | 01:24 AM
Default Mercury 200 or 225 Optimax 2 Stroke or 200 Verado 4cyl 20" shaft Smartcraft DTS
Ready to buy a new or used mercury 200-225hp outboard. Must have DTS and Smartcraft. Boat is already rigged with digital throttle and shift!
200 or 225 2 stroke
200 Verado 4 cylinder supercharged four stroke
Kevin
231-534-5060
offshorexcursion is offline
Old 04-01-2015 | 10:24 AM
Is this to be used as a bow thruster on Unleashed???
endeavor1 is offline
Old 04-01-2015 | 10:59 AM
FYI..... The Optimax motors do not have DTS, only the Verado's will work with Digital Controls.
Maritime_Eng is offline
Old 04-01-2015 | 11:20 AM
SS930's Avatar
I believe merc has offered the 200/225 with DTS.
SS930 is offline
Old 04-01-2015 | 08:46 PM
Yes at one time the 200 and 225 was offered dts. I have been told you can still buy dts smartcraft in Europe.....
Old 04-01-2015 | 09:18 PM
175HP Verado and up are nice engines when you want the power and efficiency of a four and not necessarily the handicap of the power curve and/or weight.
the previous offerings of 150 Verado's didn't idle like the bigger models... its now a memory as the smallest remaining is the 175HP.. They shift like Glass and the fuel consumption on a heavy boat is crazy compared to other engines.
A pair of clients are running single 225 Verado's. One with 750hours and the other is about 1200hours. Both needed a prop shaft carrier seal at 750 hours... other than that - regular oil (engine and lower) changes and good clean fuel.... Happy boating.
We are going to be rigging our new work boat with a pair of Verado's. One option was to go with the four-stroke series of engines... the average fuel economy was said to be about 20- 30% going to Verado's on our application
speicher lane is offline
Old 04-01-2015 | 09:49 PM
seltzer's Avatar
Friend has 1st gen 225 verado 20 in. Low hours 300 range. New lower. Priced right. Call Frank 703 5174086
seltzer is offline
Old 04-01-2015 | 10:18 PM
pretty sure 225 verado is a 6cyl which is too heavy. thanks anyways!
Old 04-02-2015 | 12:40 PM
I think from 06 and up 225 opti's can be had with dts.
turbo rr is offline
