Bravo 1 Gear Slipping >
Old 04-05-2015 | 03:44 AM
Default Bravo 1 Gear Slipping
Hello!
i have an issue with getting my gear in forward/reverse with my bravo 1's.
The problem seems to only happen when first putting into gear, which requires a little rev in order for the gear to fall into place. no problem after that once runing.
Any suggestions on why this is happening? And how i could resolve it? Thanks!
AlOstad_84 is offline
Old 04-05-2015 | 06:08 AM
Did you just change the drive oil over to synthetic?
indysupra is offline
Old 04-05-2015 | 06:43 AM
no ..
Old 04-05-2015 | 09:00 AM
I would take shifter cable of drive side off the bracket and move it by hand(while running).if it moves hard,cable may be bad.then I'd take it apart,either cone clutch is worn or the upper gears aren't lined up right.
sutphen 30 is offline
Old 04-06-2015 | 12:15 AM
ill try that, thanks Sutphen 30
Old 04-06-2015 | 01:08 AM
Both drives doing the same thing?????
Griff is offline
Old 04-08-2015 | 11:55 AM
BUP
Possible cone clutch or its glazed
BUP is offline
Old 04-08-2015 | 12:01 PM
obnoxus's Avatar
Charter Member #1171
More than likely ( hopefully ) just a cable adjustment,,,,,, DO NOT REV TO GET IT TO ENGAGE !!!! Bad things will happen
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
