Help ID 5.7LX Mercruiser Engine >
Old 04-08-2015 | 10:37 AM
Default Help ID 5.7LX Mercruiser Engine
I can't find a straight answer anywhere. Some sources say these engines are EFI, some say they are not. Some say they are Vortec heads...some say not. I guess having them hooked to bravo's throws it off.
What I do know.
5.7LX with bravo III drives
Serial numbers:
0k027498
0k027506
Drivehard is offline
Old 04-08-2015 | 11:51 AM
BUP
You should have a 1997 - 4 bbl carb rated at 250 hp propshaft. This engine has T - bolt V ignition, roller cam and what Merc called at that time Gen + cylinder heads (vortec persay). Also should have hand removable blue water drain plugs, one serpentine belt (new for 97) and RPM range was 4400 - 4800,
Also in 1997 was offered 5.7L with 2 bbl carb only rated at 210 hp propshaft. RPM range of 4200- 4600.
Volvo had the same and was rated at 215 hp at the prop. and their 4 bbl was rated at 260 hp at the prop. FYI
BUP is offline
Old 04-08-2015 | 12:28 PM
Thank you very much! A mix of what I suspected. Glad to see the Vortec heads!
Old 04-08-2015 | 12:49 PM
BUP
Its not uncommon to see bigger and or heavier boats with smallblocks using Bravo III's - basically somewhat under powered. It is very common with Sea Rays 26 ft and down, Cobalts, Chaparral, Crownlines, Regals amd so on from the REC side of boats
BUP is offline
