Just picked up a Scarab Excel 28....propped right??
So I just upgraded from a 24' Baja open bow to a 1988 Scarab Excel 28. It has a 454 bored/stroked to a 496 with aftermarket heads and cam and exhaust. Unfortunately I can't give any more specs about the engine upgrades as I can no longer get in contact with the PO.
It is a bravo 1 boat with a Bravo 1 4 blade 24P prop. When I bought the boat I was told it was a 575hp 75mph boat..... was it just a sales pitch? Most likely but the boat was in great shape and engine ran strong so I bought it.
Finally got it out this past Monday. It was about a 1-2' chop in the Chesapeake and at WOT I was seeing 4700 RPMs and 63mph GPS. One time in a back creek it touched 65mph.
Trying to decide if I should find a 23P Mirage + to test or just leave the four blade. I'm still learning about prop selection and what not.
Thanks for any input you guys could help me with.
I would look over the motor and make sure it is running right before messing with the prop..... a 496 with aftermarket heads should make good power if everything is right. replace the plugs and check them for signs of proper combustion and check the timing first. I would think if the motor is running right you should have plenty of power to turn a 24p well past 5000 rpm
Kevin,
Yeah something isn't right about that. I would follow dandercam's advice and go thru the basics first. BTW, post up some pics of your 28, maybe some engine pics would help too.
FWIW, my 28 has a 23p (3 blade) prop and it is just a stock 454 Mag.
Cheers,
Dave
Cheers,
Dave
