14096188 heads on gen6 502? >
Old 04-16-2015 | 08:08 AM
Default 14096188 heads on gen6 502?
I'm putting together two gen 6 502s they came with 14096188 casting # heads are these decent heads for these motors? Two are cracked so trying to decide wether to find two or switch all 4? Thanks
CenturyUltra is offline
Old 04-16-2015 | 08:12 AM
I'm using srp 139483 pistons
Old 04-16-2015 | 09:54 AM
Those are the open chamber LS 6 heads so they should be good cylinder heads.
http://www.gmpartsdirect.com/perform...CATID=361.html
Check if they work for Gen 6 - I am not sure
wannabe is offline
Old 04-16-2015 | 01:39 PM
gen 6 blocks are fine with the right gasket. a few gen 5's had very little meat around one cooling hole in the mark 4 head and were questionable.
dereknkathy is offline
Old 04-16-2015 | 08:47 PM
Pair for sale in swap.
800XCR is offline
