496 Vortec Cam Swap to Crane cam? >
Old 04-20-2015 | 02:30 PM
Default 496 Vortec Cam Swap to Crane cam?
Has anyone used the Crane cam Grind# HR-226/345-2S-14 IG. Part # 268731?
http://www.cranecams.com/product/car...detail&p=24305
I'm wondering what all engine modifications would be needed besides lifters and springs to run the extra lift of this cam in a stock L18 496 vortec engine?
I asked the guys at Crane and they didn't sound sure
Anyone else run this cam before?
MrLipps is offline
Old 04-20-2015 | 04:56 PM
What cam is in it now? I was thinking that was the cam used in that engine or is that the raylor 496 ho that I'm thinking of. Regardless it's a commonly used cam in the marine industry.
Do a search on this form regarding the raylor 496 builds etc. I recall there is a ton of stuff to read up on.
getrdunn is offline
Old 04-20-2015 | 08:41 PM
This engine was pulled out of a 2001 truck, so I believe the stock cam is very small:
Duration 204/210
Lift .465/.467
I believe the Mag HO (The difference between these engines just being cam and tuning if I'm correct) was:
Duration 222/232
lift 510/510
I'm don't know anything about the Raylar 496 HO. That sounds like it could be a whole different beast. I'll see if I can find some info on it tho.
MrLipps is offline
Old 04-20-2015 | 10:22 PM
apparently there is little to no room on those pistons for much more lift-duration without piston to valve interference.
dereknkathy is offline
