Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
baltek AIREX core   glassdave. >
Old 04-22-2015 | 08:09 AM
mtm's Avatar
mtm
Default baltek AIREX core glassdave.
Building a engine hatch Using airex core what thickness core material for engine hatch . 3/4?
Glassdave
mtm is offline
Old 04-22-2015 | 09:33 AM
General rule of thumb is 25% thicker than the wood that was used before.
So, if your hatch was 3/4 inch plywood then use 1 inch and so on and so forth.
Keith Atlanta is offline
Old 04-22-2015 | 10:01 AM
glassdave's Avatar
Neno the mind boggler
I use 3/4 for most deck and hatch stuff, 3/4 is much easier to find supports good loads. Airex in the four or five pound range with a good Vinylester resin. If it is flat have you thought about Coosa or SAC panals?
08 OPA High Points Champion
glassdave is offline
Old 04-22-2015 | 12:40 PM
mtm's Avatar
mtm
The mold is contoured . found a deal on 3/4 sheets airex. I was thinking baltec bolsa because I'm familiar with it. Thanks for the quick replies
mtm is offline
Old 04-22-2015 | 02:45 PM
glassdave's Avatar
what series Airex is it? Baltek is great for hatches because the panel ends up much stiffer, just have to take care with edges and through bolts.
Old 04-23-2015 | 07:25 AM
mtm's Avatar
mtm
this is the link
http://www.3accorematerials.com/prod...exreg-t90.html
Thanks again dave
mtm is offline
