Bravo gimble ring lower pin removal question >
Old 04-23-2015 | 09:30 PM
Default Bravo gimble ring lower pin removal question
I am in the process of replacing my bravo upper swivel pin using the JR Marine kit. I can not remove the lower pin. Does the lower pin just get knocked out from the top to the bottom? The pin will not budge. I tried heat with no luck. I am soaking it with penetrating oil now. I just want to make sure I am doing it right. I don't want to break anything.
Also do they sell a spacer that replaces the arm the the steering goes to? I installed external hydraulic steering and no longer need the arm.
underpsi68 is offline
Old 04-23-2015 | 10:13 PM
There's a cotter pin that goes through the lower ear of the transom assembly and through the pin
That's all that holds it in place
JaayTeee is offline
Old 04-24-2015 | 12:18 AM
Not sure about a spacer but you will need something on there. The nut on the swivel shaft above the steering arm determines the up and down clearance of the gimble ring. Should be .002"-.010" when measured at the lower pin between top side of gimble ring and gimble housing mount.
picklenjim is offline
Old 04-24-2015 | 05:34 PM
I did remove the cotter pin but the pin wouldn't budge. I let it soak in penetrating oil over night ant the pin came right out.
I need to find another steering arm.
Thanks for the help!!!
