Coupler question
Old 05-02-2015 | 03:45 PM
Default Coupler question
Getting ready to set my engine back in. Cleaning the coupler up it appeared to have a thin bead of silicone applied to the side that goes to the fly wheel just inside the bolt holes. Is this common practice or could it be the coupler is going bad. Also the bolts I removed are grade five, should they be grade eight.
the mayor is offline
Old 05-02-2015 | 03:50 PM
F-2 Speedy's Avatar
I don't see a need for a sealer on a coupler, if you change bolts, you need to make sure they are a shouldered bolt like the in it now to properly center the plate, personally I don't see a need to change bolts
F-2 Speedy is offline
Old 05-02-2015 | 04:21 PM
They are not shoulder bolts. Just Plain 3/8 hex head bolts. Thats what I took out when I removed the engine.
Old 05-02-2015 | 05:14 PM
F-2 Speedy's Avatar
They should be like these, the hole in the coupler is .372 a 3/8 bolt is .356 this will let the coupler move around and not be centered & may cause vibration
Attached Thumbnails Coupler question-%24-kgrhqr-l4e-ep-cf6-bp6bimni-%7E%7E60_57.gif
Old 05-02-2015 | 05:28 PM
Definitely not what was in it. I will be calling the local Mercury dealer Monday.
Old 05-02-2015 | 05:58 PM
F-2 Speedy's Avatar
ARP makes them if you have a local speed shop
Old 05-02-2015 | 09:02 PM
No local speed shop. Jegs or Summit have them.
Old 05-02-2015 | 10:12 PM
McMaster Carr on the bolts, and I would never silicone the coupler.
Bawana is offline
Old 05-03-2015 | 07:05 AM
loctite? hell yes. flywheel bolts too.
dereknkathy is offline
Old 05-04-2015 | 04:10 PM
Called the local Mercury dealer. They gave me the same part number I found on the Web last night 10-37612. Went to pickup the bolts after work. No shoulder just 3/8 - 16. 1 1/4" hex head bolts grade 5. They were in QuickSilver sealed bag. Counter guy looked around and got a tech involved that's all he has used. He's not sure maybe they come with an HP coupler.
