What Prestolite pump for an Alpha 1 '86 outdrive and the differences between them >
Old 05-08-2015 | 07:43 AM
phughes69's Avatar
Default What Prestolite pump for an Alpha 1 '86 outdrive and the differences between them
Ok I have a 1986 Alpha 1 outdrive and I may need a new trim pump, I think the valve block on the bottom is cracked and leaking. In 1986 Alpha's what type of Prestolite pump did a Alpha use, High pressure low volume or low pressure high volume. How do I tell the difference is it is only discernible through the part number?
phughes69 is offline
Old 05-08-2015 | 07:37 PM
Ayuh,.... Just buy one of the new plastic tank replacements, 'n plumb it in,.....
It'll work perfectly, regardless which one ya got now,.....
Bondo is offline
