WTB:   502 Mercruiser block >
Old 05-08-2015 | 02:41 PM
Default WTB: 502 Mercruiser block
I need to find a 502 block that hasn't been (now bare with me): destroyed, over-machined, sleeved, pitted, corroded, warped, over-heated, dropped or become the thing of nightmares past.
Reason you ask? I "had" a wonderful block, that I took to have a motor rebuilt into said block...that is now over-machined on one side so the pistons are .032" above the deck height at TDC. And the sleeves were not set properly (gaps at the base of the machining).
So where does that leave me?
(a) in a heap of *^%# and pissed as....well pissed enough to call the attorney...and I hate 'em
(B) in dire need of a block (Gen V) I believe.
Attached is a pic of the area below the timing cover. Hopefully the block you have sitting over under a pile of 3 year old PowerBoat magazines and empty WD-40 cans is the answer to my prayers.
Honest truth: I've paid (the fired machine shop) a handsome sum to assemble the motor once. The intake wouldn't fit in the valley, so I called another shop, who started inspecting the assembled motor and discovering the problems. So now I have a disassembled motor (again) a ruined block, and a dust-covered boat.
I'm crossing my fingers while I scratch off some lottery tickets for engine money and also hoping the inter-web finds me a block...
If you can help... PM me. I'll drive just short of anywhere (except to liberal-land) to get a block.
- Andrew
Anoller is offline
Old 05-08-2015 | 11:14 PM
rak rua's Avatar
I don't know about the money side (what you've spent already and how your budget looks) nor do I know about the boat. Maybe you've got twins so you need to match the engines? I've noticed this in the classifieds and it's seems like pretty good value to me. Could you offload the 502 and recoup a bit of the damage and get into a nice 496 instead?
http://www.offshoreonly.com/forums/s...rop-ready.html
Just a thought, good luck with whatever you choose.
RR
rak rua is offline
Old 05-09-2015 | 01:03 AM
RR
Well it's funny you should include that ad, because it's one that I have another window open for. Actually, I'm considering the 496. Bonus is that it's closed cooling.
I appreciate the assist. It's actually going into a 272 Baja. I was having the internals redone with stronger products to then strap a blower to it... although now the blower cash-oline (think: gasoline) has been soaked up by engine bs.
You would know if the 496 uses the same mounting points as the 502 would you?
Anoller is offline
Old 05-09-2015 | 01:20 AM
rak rua's Avatar
I can't be too sure about mounting points, my guess would be the engine would drop straight in. Aren't they basically the same block? I'm sure someone here will answer that question very soon.
I love closed cooling and I love later model stock standard engines over something older that's been re-built.
Good luck,
RR
EDIT: Understand about the re-build and the blower, big decisions. Mmmm?
rak rua is offline
Old 05-09-2015 | 04:31 AM
the 496 will bolt right in .however the exhaust on a 496 may be a problem in your boat depending on outlet location ..the 496 elbow is taller
even tougher if you have y pipes and silent choice ..can you swap manifolds and use yours yes ..however that's opening another can of worms as the closed cooling is somewhat connected to it
smokin' gun is offline
Old 05-10-2015 | 07:32 PM
how about a 525 sc with 90 original hours still sealed ? 603-279-7676
ledgeharp is offline
Old 05-12-2015 | 07:22 AM
I have two good 502 blocks
chris2k2 is offline
Old 05-12-2015 | 07:55 AM
Where are you located and how much and any pics?
dennis r is offline
Old 05-12-2015 | 09:57 PM
Detroit, MI , $1,200. . I can take pictures if you are interested
chris2k2 is offline
Old 05-20-2015 | 07:07 PM
if you want to go 496 i have one
tazdevil is offline
