496/ho. miss? anyone else? >
Old 09-09-2002 | 10:54 AM
fountain27ho496's Avatar
Default 496/ho. miss? anyone else?
Getting a slight hic-up at speed, thought it was rev- limit
but it has occurred at less than wot. Not all the time.
checked water filter, cleaned spark arrestor, found
vacuum line,I think, with press in metal fittings that were
not loc tighted, runs over top of motor from front right
to back left. Looking at motor, that stopped most of it
but still an occasional miss. 140 hours, any one else
with this problem. Had it checked out, no codes on the
putor. Was racing a 95 27 at cumberland couple weeks
ago and this happens, had to back off, hate that.
fountain27ho496 is offline
Old 09-09-2002 | 12:01 PM
boatfreak's Avatar
I would check fuel preasure. Put a gauge on it and run it under load should carry 42 psi. I put 80 hours on one with the same thing and nobody could figure out where the miss was coming from. It turned out the small pump behind the fuel filter was bad.l
boatfreak is offline
Old 09-10-2002 | 10:22 AM
You should have a filter before the boost pump .Between the pump & tank.
Doug
Dixie Doug is offline
Old 09-10-2002 | 10:39 AM
Default Thanks I'll check it out
Probably have to wait untill in comes out of the water
on the 30th, Is their a filter or I should put one? thanks, JC
Old 09-12-2002 | 10:06 AM
If it doesn't have one use a Racor 320RRAC02. Doug
Biligemouth
4
08-14-2008 04:42 PM
OSO News
Offshoreonly Industry News
0
02-19-2008 08:45 AM
osen007
0
05-27-2007 12:36 PM
Uncle Toys
03-04-2005 08:23 PM
fountain27ho496
1
06-12-2003 01:08 PM
