aftermarket alum heads..clear 454 mag piston domes? >
Old 05-10-2015 | 05:25 PM
Default aftermarket alum heads..clear 454 mag piston domes?
looking at a set of performer rpm 6055 heads and also considering 115 cc chambered chinesium. (they say they are australian, but...) they have the vortec-ish heart shape chambers. does that point between the valves come too close to the piston dome? it doesn't seem near as huge as the iron L29 head chamber.
dereknkathy is offline
Old 05-10-2015 | 06:04 PM
best I can say is,buy them,put them on w/ some clay and see if it works.If not,,grind the chamber to work w/ the pistons.
sutphen 30 is offline
Old 05-10-2015 | 06:08 PM
the edelbrock 6055 head comes with a 118 cc combustion chaimber and is pretty much a aluminum version of a gm rect port head.it is a good choice for a replacement head but won,t flow anything near what a dart or afr head will.i have no info on the chinese heads and i won,t use them.
mike tkach is offline
