Lift points on a '83 Scarab 377 >
Old 05-11-2015 | 09:33 AM
Default Lift points on a '83 Scarab 377
I'm new to the forum...thanks in advance for any responses. I'm building a dock with lift for my '83 Scarab 377 and the dock builder has requested lift points. I have the owner's manual but it does not have the info. A quick search on the internet wasn't very helpful either. My dock builder has an idea of where he will put them if we can't find it (he owned a , but I would certainly like to be correct on this than just taking an educated guess. I inadvertently posted this to the "safety" section of the forum, which doesn't appear to get much traffic (hehe).
Thanks again for any help tracking this info down
Space Toast is offline
Old 05-11-2015 | 10:43 AM
phughes69's Avatar
I am assuming that your lift is using straps. If that is the case I would put the rear most strap at a point 1/2 way between the transom and the front of the engine. This way it is supporting a good portion of the weight of the boat. For the front, make sure you place it as close as possible to a bulkhead. Maybe the 3rd bulkhead from the front
phughes69 is offline
Old 05-11-2015 | 11:53 AM
I should have clarified...it will be a 16' cradle lift. I'm essentially looking for the point where the weight is balanced front-rear.
