Man those XRs are tough drives! >
Old 05-12-2015 | 03:44 PM
Default Man those XRs are tough drives!
http://www.screamandfly.com/showthre...-boat-go/page2
JRider is offline
Old 05-12-2015 | 03:50 PM
1400hp huh?
*cough*bullsh*t*cough*
Nate5.0 is offline
Old 05-13-2015 | 06:49 AM
Originally Posted by Nate5.0
1400hp huh?
Well he isn't running 130+mph with a 525EFI...
https://youtu.be/F10wOXk4k3A
Plowtownmissile is offline
Old 05-13-2015 | 06:59 AM
Damn thing is fast though.
JRider is offline
Old 05-13-2015 | 07:09 AM
Dean Ferry's Avatar
Veteran: Air Force
That's for sure!
Everything is for sale @ a certain $$
Dean Ferry is offline
Old 05-13-2015 | 08:30 AM
Hey if you see my brothers sisters cousins friends boat you better just turn around and go home J !!
1400hp and and XR ? Must be a dyno/trailer queen.
ICDEDPPL is offline
Old 05-13-2015 | 08:54 AM
Fast but the music,,,,,,
Wildman_grafix is offline
Old 05-13-2015 | 01:21 PM
dcb
Just had one of my XRs gone through - found race on top cap cracked and - pitting on the gears! Well maintained XRs was told that pitting is the beginning of failure. 250 hours.
dcb is offline
Old 05-13-2015 | 01:42 PM
If you got 250 hrs out of a XR you are damn lucky in my book! You should go buy a few lotto tickets...I check mine every 40 hrs no matter what.
Cobra100+ is offline
Old 05-13-2015 | 01:55 PM
articfriends's Avatar
Alot of hp for a Bravo based drive, I personally have ran 1100 hp in front of my Bravo XR upgraded drive, has cry iso rem'd gears, billet 300 m shafts, all max machine works upgrades. When I run a 30 pitch labbed with my 1050 hp pulleys I have gotten 40-50 hours between breaking things/replacing things, when I run the 1100 hp pulley and a 32 pitch I usually break something in 10-15 hours but My boats a V-hull, not a Cat. When I tried a 5 blade I almost instantly sheared off a Max worx billet 300 m prop shaft, have broken several of there billet vertical shafts. Its only a 27 vee so it doesn't get ran at much boost in anything over a true 2 footer either, I can imagine IF you could actually go fast in rough water it would almost break instantly. I go thru drive about every 30 hours if it hasn't broke yet and inspect all the parts, have caught many parts ready to fail also, fwiw
articfriends is offline
