Used BMAX Outdrive
Old 05-16-2015 | 12:32 PM
teaguecustommarine's Avatar
Offshoreonly Advertiser
Default Used BMAX Outdrive
For you guys looking for a used drive, here you go. Here is your new, used BMAX! Take off from a customer owned Howard 26 cat.
Good housings, low water pick-up, good u-joint's and shafts (1.25" prop shaft), 1.3ish ratio, etc. Needs cone clutch and is being as sold as is..
$1,899.00 obo, come and get it. -Eric
http://teaguecustommarine.com/em0011...-outdrive.html
[ATTACH=CONFIG]541117[/ATTACH][ATTACH=CONFIG]541123[/ATTACH][ATTACH=CONFIG]541119[/ATTACH][ATTACH=CONFIG]541118[/ATTACH][ATTACH=CONFIG]541120[/ATTACH][ATTACH=CONFIG]541121[/ATTACH][ATTACH=CONFIG]541122[/ATTACH]
Attached Thumbnails Used BMAX Outdrive-1.jpg   Used BMAX Outdrive-2.jpg   Used BMAX Outdrive-3.jpg
teaguecustommarine is offline
Old 05-17-2015 | 04:06 AM
I want this please call me at 616-799-6187 thank you Dennis
dennis r is offline
Old 07-08-2015 | 12:10 PM
Default Sold!
Drive is SOLD!
Old 07-08-2015 | 12:21 PM
At that price, wow killer deal
drpete3 is offline
Old 01-26-2016 | 04:08 PM
Panther's Avatar
Frank's Marine Service
That was a great deal assuming the upper gearset was good. Probably just needed to reset the stack height in the gearset to get the shifting to work.
Panther is offline
