Guess the horsepower
Old 05-20-2015 | 06:35 AM
From: Central Square & Fishers Landing, 1000 Islands NY
Default Guess the horsepower
Ok......we are going to have a little contest to see who can guess the horsepower that my (3) new Bob Madera spec'd boat motors make when they go on the dyno. Closest without going over will win something, just not sure what. Here are the details of what they are:
548 ci
AFR 325 aluminum heads, CNC ported, hand matched to intakes
Bob Madera/Marine Kinetics roller cams (specs proprietary)
Dart dominator intakes
ProSystems 1150 Dominator carburetors
Callies Compstar crankshafts
Diamond pistons
Scorpion roller rockers w/stud girdles
MSD billet distributors
MSD 6al boxes
Dry exhaust to the tips to prevent reversion due to the cam
91 octane pump gas
5800 rpm's
1000 islander is offline
Old 05-20-2015 | 06:56 AM
696 HP with 682 TQ at 4700 RPM's on a properly calibrated DTS dyno (if your going on a 901 it depends on the "wish" dial setting).
brian41 is offline
Old 05-20-2015 | 07:02 AM
Full Force's Avatar
716 hp@6000 and 696tq@4600
Full Force is offline
Old 05-20-2015 | 07:05 AM
Wobble's Avatar
SORE MEMBER
750hp
edit
thats dual dominators?
I am in for 850
I read it again, single dominator carb on 3 motors LOL, so back to my original 750hp
Wobble is offline
What did you think of the Compstar crank? Their rods looked nice.
Cole2534 is offline
Old 05-20-2015 | 07:06 AM
Compression ratio?
712 HP
kreed is offline
Old 05-20-2015 | 07:07 AM
My boat is a 91 non stepped 42 Fountain with triples. It ran low to mid 80's on the old hp500's with around 560 tired horsepower apiece at 5000-5100.
Callies Compstar stuff looks nice, the AFR heads are beautiful.
Old 05-20-2015 | 07:13 AM
Full Force's Avatar
Originally Posted by kreed
Compression ratio?
712 HP
I will bet 9.6:1 with .030 gasket
Old 05-20-2015 | 07:18 AM
SS930's Avatar
Without knowing the cam specs and comp, the output could be anywhere on the map... but given the lack of info, I'm going to guess 682 hp.
SS930 is offline
