I propose that everyone who owns a mercruiser product gets...... >
Old 05-20-2015 | 09:10 PM
seafordguy's Avatar
To kick the mercury engineer of their choice in the nuts.
I am choosing the engineer who designed that stupid manifold assembly on the bottom of the transom assembly for the trim hydraulics. My blood pressure was through the roof on that thing today. There is just no way that could be the best possible design......
seafordguy is offline
Old 05-20-2015 | 09:19 PM
or the a-hole that decided trim pump and drive lube brackets should be painted steel, fk him!
pstorti is offline
Old 05-21-2015 | 06:56 AM
I get the guy (idiot) who designed the upside down oil filter!
JRider is offline
Old 05-21-2015 | 06:59 AM
Poke a couple holes in it and give it 20 minutes. You'll like that filter a lot better!!
tmmii is offline
Old 05-21-2015 | 07:01 AM
I get the shift cable guy... Do one on an omc then go back to merc and see what I mean
Unlimited jd is offline
Old 05-21-2015 | 07:13 AM
From: Central Square & Fishers Landing, 1000 Islands NY
Or the bozo that decided to mount the seawater pump down on the very bottom where you can barely get at it with stringers and motor mounts in the way. Had to be the same asshat that came up with the upside down and horizontal oil filter mounts.
1000 islander is offline
Old 05-21-2015 | 09:04 AM
Same guy that choose to build the water pump out of brass... He probably owns stock at Hardin...
alindquist is offline
Old 05-21-2015 | 10:13 AM
Dibs on the gasket designer that decided compacted dandelion fuzz was a better material than any of the miscellaneous rubber compounds available.
Speedracer29 is offline
Old 05-21-2015 | 02:19 PM
I like this thread!
pstorti is offline
Old 05-21-2015 | 02:48 PM
From all the reading I have done here I'm SHOCKED that the fabulous BRAVO DRIVE wasn't at the top of this list!
Diamond Dave is online now
