342 / 33 Outlaw owners, question >
Old 05-21-2015 | 08:45 AM
Default 342 / 33 Outlaw owners, question
We know that if you have th3e big cockpit/ small bildge, impellers are a *****.
Removing the seat back is the way to go for sure.
when I did mine, I lossend both hose clamps (intake and out put), and removed bolts, and pulled pump strait off the 2 hoses. and when I installed them I litterally used the bolts to pull the pump back on the 2 hoses..
So here is my question. has any of you ever changed it while FLOATING... if so, how did you do so? I could not see how to move my intake hose above the water line as it had no wear to go... so seems thats not going to ever happen if your in a jam stuck somewhere in the water.
mittens is offline
Old 05-21-2015 | 08:58 AM
After you try it, report the results....
I would think that you would be able to remount the pump if water started gushing out. Like you said, its above the waterline.
Keith Atlanta is offline
Old 05-21-2015 | 09:30 AM
I was under the assumtion it was BELOW the water line and that water would GUSH in... I know most boats are set up that the wateris natrually pushed to the pumps.. so I assumed it would rush in.
mittens is offline
Old 05-21-2015 | 12:45 PM
I removed the hoses and shoved a rag in the inlet hose, then went to work....it was around 100*, so I had the wife keep driving the boat ( @ idle)
to keep some air movement, lost a pint or two of blood during the battle, but got it done
JaayTeee is offline
Old 05-21-2015 | 02:37 PM
SO how much water was rushing in with this hull in the water?
mittens is offline
Old 05-21-2015 | 04:38 PM
A little water poured in ( probably about a quart) when I pulled the hose off the pump, then I stuffed a rag in the hose
JaayTeee is offline
Old 05-22-2015 | 04:50 PM
Make a pvc plug get a pipe glue a cap on disconnect the hose it wont me a major rush but you will get water insert the pipe in place a clamp on and clamp.
boomer is offline
