Drilling an additional ram mounting hole in K-plane >
Old 09-09-2002 | 09:19 PM
blackhawk
Default Drilling an additional ram mounting hole in K-plane
I installed longer K-planes on my boat last year. Helped the boat handle a lot in the slop but did scrub about 2 mph off the big end in flatter water. I was thinking about installing shorter rams to bring them up a little farther. But looking at them it would be a lot easier to drill another hole about an inch or so behind the stock hole which would bring the tab up farther. But, I want to make sure that this will not weaken the plate. Anyone done this?
Old 09-09-2002 | 10:21 PM
Tinkerer's Avatar
Why not just fill the original hole and reinforce around the new hole???
Tinkerer is offline
Old 09-09-2002 | 10:45 PM
blackhawk
Tinker, I will fill the original hole if it works. The new hole would still be in the strong part of the casting. I just want to make sure that the two holes that close together wouldn't weaken it.
Old 09-10-2002 | 01:59 PM
blackhawk
Anyone, anyone? No one has tried this? I don't want to be the first!
Old 09-10-2002 | 03:51 PM
The pressure point of that hole is on its top and bottom, not so much front to back, so a hole behind it, you wouldn't think it would be to much weaker. Then again anytime you drill anther hole you are effecting the integrity of the assembly.
The rib that the ram connects to, is it the same size an inch behind the original bolt hole, or does it taper down? If it tapers down, meaning you won't have as much stock on top and under the hole you are drilling, then it will not be as strong.
Good Idea, worth investigating.
Danny Usnik is offline
Old 09-11-2002 | 09:48 AM
blackhawk
Danny, the rib is the exact same size one inch behind the stock hole. That is what got me thinking.
My logic was most of the stress is on the bottom and the "back" of the hole(water is putting upward pressure). I think I would be fine if the new hole did what I wanted it to. However, my concern was that if it didn't and I had to go back to my original hole, would the "back" of that hole now be weaker?
Old 09-11-2002 | 09:55 AM
Wally's Avatar
Were doomed!
Why not just machine a block of aluminum or other metal to fit inbetween the opening where the ram used to be and put a nut/bolt through it to take up the space and take any stress off that there may be there? any thought on that idea?
-Wally
Wally is offline
Old 09-11-2002 | 09:59 AM
blackhawk
Wally, that's a damn good idea for reducing the stress. I was hoping that someone else had already done this so I didn't have to be the one experimenting. But I may have to!!!
Old 09-11-2002 | 10:52 AM
Blackhawk,
Thinking about this last night. The rib being the same size behind the exsisting hole is good. Now that you brought up the point of moving the ram back if it does not work. That is a new hurdle, if you have to move it back it will be weaker behind the ram connection.
Most of your pressure is aft of the ram. So if it will not work and you move it back you will deffinatly have to do something with the hole you just drilled. I like wally's idea of putting a machined componant in the unused hole, that will deffinatly help with absorbing the shock.
I think this will work. I would suggest doing the math on the distance the tab with move with how far back to drill the hole. I think if you put the hole in the right spot this will work without question and you won't have to worry about putting it back.
Another suggestion, when you make the componant to go into the unused hole. Make the componant the same size. .500" hole make .500" pin. Now freeze the pin for a day to shrink it a small amount so you can get it in the hole. When it warms up it will be a perfect fit. This will be the strongest fit. Zero tolerance.
Just putting something close will not add strength.
Good luck, keep me posted,
Danny
Old 09-11-2002 | 10:56 AM
Wally's Avatar
Were doomed!
You do realise that with moving the ram out farther....thus raising the tab up higher you will loose a little in the doward position right? I dont know how far down you need the tabs to go but its just something to keep in mind.....
-Wally
Wally is offline
