Need Hard to find TRS PART or Specs >
Old 09-10-2002 | 10:01 AM
Audiofn's Avatar
Charter Member #232
Default Need Hard to find TRS PART or Specs
I have a problem. On my boat I have TRS drives with Merc Transmisions. There is a "pilot" Bearing that goes in the cranc of the engine and keeps the drive shaft on the trany from moving that is missing in my set up. I have looked for one and no one seems to have them. Does anyone have one or the specs so that I can have my machinist make it? I could pull both motors and take measurements from the other but that is a HUGE pain in the butt that I would like to avoid.
Jon
Put your best foot forward!
Audiofn is offline
Old 09-10-2002 | 10:13 AM
Doller has it listed in their parts website. NLA?
Gary
Gary Anderson is offline
Old 09-10-2002 | 10:22 AM
Audiofn's Avatar
Charter Member #232
Gary NLA= No Longer Available
Audiofn is offline
Old 09-10-2002 | 10:26 AM
My "NLA" was a question. They still list a price on their site. Have you called them? They also have good connections on rare parts.
Gary
Old 09-10-2002 | 10:46 AM
Audiofn's Avatar
Charter Member #232
Garry I have not called them no. HOWEVER I will I tried local places and they all said NLA to me. I will give them a call however. I am sure some one must have one sitting on a self somer were...... I hope
Audiofn is offline
Old 09-10-2002 | 10:57 AM
If you strike out with Doller, let me know. I have a couple local sources with a lot of old parts laying around. It just takes a couple weeks for them to find it.
Gary
Old 09-10-2002 | 11:05 AM
Audiofn's Avatar
Charter Member #232
I have tried Dollar, Sea Way Marine, Rigs, Supriem, and Jay Catelone. All say no go.
The part Number I have is 23-71647 does that match up to what you have?
Jon
Audiofn is offline
Old 09-10-2002 | 11:08 AM
Wally's Avatar
Were doomed!
Jon, how hoard would it be just to have a machine shop make one for ya?
-Wally
Wally is offline
Old 09-10-2002 | 11:12 AM
These guys don't need no stinkin' part numbers. They just have a lot of boxes of old stuff. I'll call them and see if they pulled any merc trannys in thev last couple years. They're getting REALLY rare though. If they dont have the bearing, I'll see if they have a tranny to measure the input shaft diameter. A machine shop should be able to bore or sleeve a standard GM pilot bearing to the correct ID pretty cheap.
Gary
Old 09-10-2002 | 11:21 AM
Audiofn's Avatar
Charter Member #232
Wally if I had the dimensions it would be a snap unfortunatly that would require me to not only remove the engine but take precise measurements that I am not 100% sure I can pull off. There has to be a few of these floating around some were!!!!
I also tried Bam, and a couple others. Bam got me some hot leads that I am now chasing.
Audiofn is offline
