6.7 to a 7.3
Old 05-31-2015 | 03:43 PM
Default 6.7 to a 7.3
I just sold my 2011 6.7 dually because my boat sits on a lift at the lake and I don't need it to travel with, but still needed a big truck to pull the boat when needed. I picked up a very nice no rust 2000 f 250 7.3 but I am spoiled to the power of the 6.7. I have been told you can really wake the 7.3's up with out killing them. Anybody had good reliable results for mild tunes with the 7.3 to make it closer to the power of a 6.7?
dave krehbiel is offline
Old 05-31-2015 | 05:29 PM
It's hard to compare the two mostly because of the transmissions behind them. The newer transmissions and the rpm capabilities of the newer diesels are nice. The 7.3 will wakeup a bit with an exhaust,intake,and a tuner. After those mods it gets a little more involved for bigger power.
turbofox54 is offline
Old 05-31-2015 | 05:42 PM
Leave it alone and enjoy it for several hundred thousand miles. I have 2 now, had 4 in total over the years, over 500k miles in total no major issues. My 2000 dually has a dp tuner 6 position in it, I just leave it on the 50hp tow tune, and have a big wix air filter on it. 16 mpg hwy, 11 towing.
Btw my first one had everything, banks inter cooler, water meth inj, n20, injectors, turbo, etc. never a reliability issue under 500hp, but now after building several different big power diesels I enjoy the easy turn key no worries lol
Unlimited jd is offline
Old 05-31-2015 | 06:56 PM
go to riffraffdiesel.com they can get you your best bang for a buck..like mentioned a simple 80 hp chip and exhaust is all you really need..spend the extra and go for the SS exhaust..
FIXX is offline
Old 05-31-2015 | 07:01 PM
ps ck their sale sexction..
FIXX is offline
Old 05-31-2015 | 08:02 PM
I did a Tony wildman 6 position chip, garret Gt40turbo, 200 over 100 injectors by full force, modified hpop, 4" down tube, 5"exhaust, intake kit, 6.0 trans cooler, deeper trans pan, trans go shift kit, tripple billet converter, hardened trans shaft and high pressure pump in trans, lift pump at tank to force feed it the fuel, the in fuel pick up tank modification. Ran like a hooker to a 50 dollar blow job!
The Tony wildman chip and trans go kit with intake and exhaust woke my second one up.. Way better than a he off shelf crap of bully dog banks etc...
JPD Motorsports is offline
Old 05-31-2015 | 08:51 PM
VoodooRob's Avatar
I just went from 7.3 to 6.7 and totally agree with you, there is a big power difference. Really like how quiet the new engine is. Nothing like the 7.3 turbo whistle though.
VoodooRob is offline
Old 06-01-2015 | 06:46 AM
remember you are trying to hot rod a 16 year old truck.......I'd leave it stock and enjoy it and at this point it probably preserves the resale value being stock
Jupiter Sunsation is offline
Old 06-05-2015 | 03:30 PM
Thanks for the responses guys, I have been swamped at work and have not been able to get back on here. Since then I have put a 4" magnaflow exhaust on it and have decided on a superchip tuner. A good diesel mechanic friend of mine told me that's all it would need for a little more reliable power without hurting it. I won't be using it that much but I do like the old school diesel so far!!
Old 06-05-2015 | 04:17 PM
Its simple to buff up a 7.3 the problem is the e4od tranny....it aint going to like it one bit.... kinda like a wife here one day gone the next....
Pliant is offline
