Electrical question / Replacing a light.
Greetings all. I am new to the site and this is my first post... (Go easy on me.)
I have a 1989 Formula with the "Silent Thunder" exhaust box.
This past weekend, as I was doing my pre-season inspection, I noticed that the lens on my flush mount stern-light was all but blackened out. I removed the stainless shroud and disassembled the light housing. Long story short, the entire light assembly needs to be replaced. I noticed that the lead wires that pass through the transom (and silent thunder box) are a little on the short side.
I have the new light assembly and am planning on doing this job tonight since the boat is still on the trailer.
The question is:
Should I be able to cut the lead wires and pull them back in through the transom to lengthen them, or will I have to drop the exhaust box? (And yes, I do know what removing that box entails. lol)
Thanks for the read. Hopefully someone has done this before.
The question is:
On my 87 224LS, I know similar hull different top. My stern lamp wire comes through the upper transom and does not pass through the Silent Thunder box at all. if you have trouble just solder on a bit of extension wire.
