Go Back  Offshoreonly.com > General Discussion > Offshoreonly Industry News
Livorsi Marine - New GPS speedometer kits with 10 time per second update. >
Old 06-04-2015 | 05:25 PM
KennyOffShore's Avatar
Administrators
Default Livorsi Marine - New GPS speedometer kits with 10 time per second update.
Livorsi GPS Speedometers are more accurate than ever with the new GPS antenna with a 10X update. What does this mean? It means your GPS Speedometer will show your true speed faster because the antenna updates 10 time per second. Pointer lag is eliminated and there is no calibration required.
Antenna Features:
  • Fast 10 Hz 10x update
  • 4 ft harness with ring terminals
  • NMEA 0183 compliant
  • No calibration required
  • For marine, ski boat and automotive applications
GPS Speedometers
Mega and Race series GPS Speedometers
Mega and Race Series GPS Speedometers are available in standard or oversize cut outs with 5 dial options, 12 rim colors and two rim styles to choose from.
  • Kit includes:
  • GPS speedometer
  • antenna - NMEA 0183 compliant
  • memory recall switch and switch plate
  • harness
Mega and Race GPS Ski Speedometer
Mega and Race GPS Ski Speedometer is available in standard or oversize cut outs. This gauge features an expanded scale from 10 to 40 MPH.
Kit includes:
  • GPS speedometer
  • harness
GPS Speedometers with Odometer
This standalone GPS Speedometer with Odometer is a digital gauge driven by a GPS antenna with a 10X update.
Combines an analog and digital display in one gauge. LCD screen features an odometer and three trip odometers to help you determine your GPM.
  • Kit includes:
  • GPS speedometer
  • toggle switch to navigate LCD screen
Arched, Standard and Billet
The PLATINUM SERIES is designed to be ergonomically comfortable to the operator while being lighter and compact for tight spaces. The Platinum Series controls are finished with a two coat process which prevents corrosion and can be configured for single or multiple engines - Drives, Transmissions, Jet Drives or Buckets. Available in three throttle/shift configurations: Fully Mechanical, Fully Electric or Mechanical-Electric Hybrid.
Configurations include one or any combination of the below:
  • The use of mechanical 33C or 43C cables for mechanical levers
  • Electric configurations use compact direct driven angular sensors - 0-5 Volt electronic sensors or a PWM signal
  • The use of a micro switch for electronic transmission shifting
  • Single, twin and triple in-handle trim switch available as shown on the chrome control above
  • Check with the engine manufacturer or Livorsi Marine for electric control compatibility
KennyOffShore is offline
HTML code is On
