MSD website
Old 06-06-2015 | 09:48 AM
Tinkerer's Avatar
Default MSD website
What is wrong with there website. none of the links work. I have tried to open them on two different computers?
who has the best prices?
does the marine BBC distributor work on a tall deck block also?
Tinkerer is offline
Old 06-06-2015 | 09:59 AM
i don,t know about their website but for it to work on a talldeck you need either a dist with a slip collar or a manifold machined for a standard dist .
mike tkach is offline
Old 06-06-2015 | 10:07 AM
Tinkerer's Avatar
HI Mike - They don't offer anything on the website for a tall deck marine distributor.
Mike I was thinking on using the Holley HP EFI control to just do the ignition for this summer and then next winter when I add the Procharger convert to EFI by adding the other needed components. Is this practical or should I just go with MSD and later convert.
I was looking at the MSD crank trigger and crank trigger distributor if the marine distributor won't fit my tall deck.
The other ignition control option was the Daytona sensors unit.
What are your thoughts on this.
Steve
Tinkerer is offline
Old 06-06-2015 | 11:21 AM
Web site works..........msdperformance.com
benjen is offline
Old 06-06-2015 | 08:54 PM
Tink, you can have the colar on your distributor machined off in a lathe. I takes two minutes. Even with a tall deck intake that has been machined to use a standard distributor the distributor usually ends up to high...
Black Baja is offline
Old 06-07-2015 | 12:46 AM
You've been watching too much free porn and ur pc has a virus as a result
iliveonanisland is offline
Old 06-07-2015 | 12:48 AM
Not that there's anything wrong with that... As long as it isn't gay porn...
Do you have a sailboat?
Old 06-07-2015 | 12:50 AM
What u don't have a harbor freight bench grinder?
Msd sells a slip collar so u can adjust the height
Old 06-07-2015 | 06:17 AM
No, I have a huge Dayton grinder that sounds like a jet airplane when you turn it on. It requires about 500ft lbs to hang onto whatever your grinding and spits stuff from when end of the shop to the other. I'd much rather run over to my buddies shop and throw it in the lathe cause the bench grinder is a little intimidating.
Old 06-07-2015 | 06:53 AM
Is this ur lathe?
http://m.youtube.com/watch?v=xRemQqAodz8
