Info about motor oil pumps >
Old 06-06-2015 | 11:47 AM
BUP
Default Info about motor oil pumps
I am looking at trying to make a better motor oil changing pump. I have use the Jabsco unit for so many years and have experimented with many others. The Jabsco unit has done a good job basically if you are doing about 50 oil changes per year and maintaining the impeller and not letting the pump run dry, overheating it.
Does anyone have experience of a better oil pump on the market to build your own system that can handle about 50 to 150 oil changes per year. especially a pump that does not have an impeller or even if it has an impeller.
I have been looking at Reverso as well but think a system could be built for less money and do just as good if not better of job especially for someone that changes motor oil at the marinas. Thanks.
BUP is offline
Old 06-06-2015 | 01:16 PM
glassdave's Avatar
Neno the mind boggler
I have a Tempo vac type pump and like it but it does take some more effort because you have to pump it up manually. In my mind its no more work then hookin up wires and has less moving parts so its almost always guaranteed to work.
I am thinking about putting a permanent system on my Scarab to do the oil changes but have a flush mount panel with fittings maybe on the transom or something. I have a pre oiler that i pulled off a boat that will work for the pump. That Reverso seems crazy expensive for what it is really. Yeah i would think you could build that for much less and probably better.
08 OPA High Points Champion
glassdave is offline
Old 06-06-2015 | 01:29 PM
now i have a vacula fluid extractor ...grew out of it ho...this will be my next one with a long hose..
http://www.sears.com/lincoln-lubrica...&blockType=G18
FIXX is offline
Old 06-06-2015 | 02:43 PM
glassdave's Avatar
you ever use an air venturi powered anything? . . . . . noisy air hog but that does look like a nice big system.
Old 06-06-2015 | 02:53 PM
my cacula is real quoet..all you hear is a slight hiss...
FIXX is offline
Old 06-06-2015 | 02:58 PM
SB
I have the mityvac 7400. Same deal as yours.
20/50 oil when cold takes a bit, but when warm, it sucks i up pretty quick.
http://www.amazon.com/s/ref=nb_sb_no...luid+extractor
I've had it for 10+years now. Still works great. I use it for many things around work and home.
I bring a 5 gallon 'blue' plastic gas can with me, along with a funnel, so I can empty it's contents into it.
I have waste oil heat at work...so easy for me to ge rid of waste oil. LOL.
SB is offline
Old 06-06-2015 | 03:02 PM
Full Force's Avatar
5 gallon gas can, 5/8 hose, garden hose fittings and a harbor freight pump, 50.00 in parts works great!!
Full Force is offline
Old 06-06-2015 | 03:53 PM
Wobble's Avatar
SORE MEMBER
I use a holley blue fuel pump, works very well. It was the only thing that could suck the milkshake out when my intake gasket failed last year. Has been very reliable for years.
Wobble is offline
Old 06-06-2015 | 04:07 PM
heads up...dont refer it as waste oil..epa considers that the type of oil you cant burn..cost me almost a grand to get rid of a sealed 5 gallon bucket of just used motor oil that a customer driped off and put the word waste on it.. they consider the word waste not useable at all..phuckin satety clean..thankyou..i also have a used oil heater that only burns used motor oil..ps i also found out that they can only come in your shop if they see a oil container so hide those as well..that bucket cost me a lot of money because it was sitting by the back door and had waste on it..
FIXX is offline
Old 06-06-2015 | 05:02 PM
glassdave's Avatar
I was thinking that maybe a good fuel pump would work as well. Good to know it does . . . .
