Best distributor advance curve for a MSD ignition on a bravo magnum 454?
Has anyone experimented with the spring selection to develop MSD advance curves with a bravo magnum 454 gen4? It looks like curves B and C are similar and top out around the max rpm for my motor (around 4600). I had decent results with the factory set up but would like to dial it in better with winter additions of a new carb, headers and intake.
Thank you,
Jim
Thank you,
Jim
Thank you,
Jim
Thank you,
Jim
exactly,,merc dist w/ v6 or hp-v8 module.or for less work,stock 350/454 distributor from the 88-95 era,2 wire hook up,just need the right internal module as I've seen a few come thru w/ no limp/back up advance curve programmed into them.
I put some holes in the bottom of my cap to try to vent it better to see if that would help with the rust. Did not help much. I put a crank trigger on it and pulled everything out of the distributor but the rotor button. Now that helped.
I've been running msd distributors for quite some time now. I learned years ago about their "rust" issues.
In 2010, I sent both rust buckets back to MSD to be rebuilt. They came back like brand new. I coated the internals of them with CRC SP-400. The reluctor, magnetic pickup, shaft, etc, all still looks like the day I coated them 5 years ago.
The CRC stuff has impressed me. It does exactly what is supposed to do.
http://www.crcindustries.com/ei/prod....aspx?id=03282
I do agree though, for a basic 454 merc, the stock ignition is hard to beat.
the stock cams are pretty mild, and don't really "need" more base timing than the setup using the 24* V8 module. The option to use a V6 module is always there too if you installed a hotter cam too.
