Mercury Racing HP 500 motors >
Old 06-09-2015 | 03:54 PM
Default Mercury Racing HP 500 motors
This is a 1999 Mercury Racing HP 500 carb race engine. This engine was factory sealed when I got it and had 130 hours. It sat for 4 years and was taken apart for a rebuild/refresh. This motor was built back to factory specs. Block, crank, rods, and pistons, where all checked, tested, and cleaned. They also prepped the block with a fresh bore, cleaning, cam bearings, freeze plugs, and all oil passage plugs. The heads where rebuilt by George at Southern Style Race Engines in St. Pete, FL. Engine has new, high volume oil pump, bearings, pistons, timing set, crane lifters, ARP head bolts, distributor rotor and cap, plugs, gaskets and seals. I have all receipts for parts, and labor done. Motor will come exactly as seen, flywheel, coupler and all accessories (including servo pump) is also included. I think I have the offshore motor mounts too Asking $7,995.00
I also have the second motor to this pair, but it needs a rebuild. You can have the pair for $11,000.00
skydive is offline
Old 06-10-2015 | 04:52 PM
Check your PMs
smokediver is offline
Old 06-15-2015 | 12:07 PM
SBX
Still have these? Or one of them? I dont see a pic in the post, where it says will come as pictured.
SBX is offline
Old 06-25-2015 | 09:54 AM
If u still have the one that's already been rebuilt. Can u post a picture or txt it to my phone. Thanks! 740-971-3334.
89Ultra1 is offline
