Trailer Question
Old 06-10-2015 | 06:42 PM
Default Trailer Question
Anyone use a Load Master trailer to pull boat? just wondering how do you like the torsion axles? Mine is a 2001 model and the torsion has weakened to the point of bottomed out. No torsion, like running straight axles. New axles are about $700 a piece. debating on buying those or replacing with axles and springs.
01scarab29 is offline
Old 06-10-2015 | 07:41 PM
Sydwayz's Avatar
Forum Regulator
What rating are the axles you are running? That's not typical unless overloaded.
Sydwayz is offline
Old 06-10-2015 | 08:31 PM
I paid $325 for a 3500 torsion axle complete with hubs.
turbo rr is offline
Old 06-10-2015 | 09:22 PM
Rookie's Avatar
Tandem or triple axle? And how many pound axles?
I went from triple 3500# spring/weight distributing axles to tandem Dexter 6000# torsion axles and really like it.
Best prices I could find. Drop shipped 2 custom axles straight from Dexter to my shop door. (shipping $125)
http://www.ebay.com/itm/New-6000LB-D...5f87dd&vxp=mtr
Rookie is offline
Old 06-10-2015 | 09:56 PM
turbo rr ,, rookie ,,
axles are 5200lb rating ,, tandem carries 29 Scarab
Old 06-10-2015 | 10:59 PM
Sydwayz's Avatar
Forum Regulator
I'd rather have torsion over leaf springs any day of the week.
While that should not have happened on the load you described, perhaps you caught a couple of Monday or Friday axles when originally built.
Does the boat live on the trailer?
Do you always park it on level ground?
I'd replace with a new set of axles, either 5200 lbs. or 6000 lbs. if easy enough.
On my last boat trailer, I had both torsion axles bend outside the frame rails due to being overloaded. I ended up replacing with the exact same axles, and made sure to manage my weight. (Twin 3500# axles under a load that was 7280# fully loaded)
That trailer is doing fine some 10+ years later.
FWIW, this is an interesting little concept:
https://www.offshoreonly.com/classif...er-o61183.html
I'm going to take a closer look at my trailer at some point and see if my cross members would actually take the weight vs. the axles. If so, I might invest in something like it.
Sydwayz is offline
Old 06-11-2015 | 09:48 AM
that trailer saver holds up the trailer by the axles, so your springs are still holding the weight. What's the point? Preventing flat spots on the tires? I like how it says it will prevent flat spots in the bearings and hubs as well. I have never seen that happen
performancems is offline
Old 06-11-2015 | 10:08 AM
Sydwayz's Avatar
Forum Regulator
That's why I stated it was interesting, but I wasn't endorsing it. With proper maintenance, I think axles seals, bearings, and the tires are not of concern.
HOWEVER, if the CROSSMEMBERS of the trailer were the lowest portion of the trailer, and NOT the axles, I could see great benefit of the product/idea.
Such would be a good reason for building a trailer with a couple taller (lower) crossmembers.
Sydwayz is offline
Old 06-11-2015 | 10:22 AM
I used to haul big wrecking style dump trailers for a demo company. They built their own trailers. They had a very cool feature. Obviously semi trailer with air brakes/air suspension. Anyhow, the suspension was a triple axle air bag setup. The trailer had air valves on the side. You can raise any axle off the ground, by pushing a button. Want to raise the front of the 3 axles, push a button. Want to raise front two axles, push two buttons.
This was a nice feature, as I would often have to back a big wrecking trailer into tight alleys and what not. So, sometimes, I would raise the rear axles off the ground, which made it easier to get in/out of tight quarters. Obviously all 3 on the ground when going down the road loaded.
I think this would be cool on boat trailers. Air bag suspension, with the option to raise the axles. Sometimes backing up a triple axle boat trailer in a tight spot can be hard, but also tough on the axles from the twisting/jackknifing . Prob not something for the average boat, but at the cost of some of the big boy boat trailers, I think it be pretty cool. I know on semi trailers, it really isnt much more cost to opt for air ride suspension over spring suspension.
MILD THUNDER is offline
Old 06-11-2015 | 10:26 AM
Knot 4 Me's Avatar
I've had torsion and spring axles and prefer torsion.
Knot 4 Me is offline
