bravo 1 or x drive >
bravo 1 or x drive
bravo 1 or x drive
Old 06-11-2015 | 05:27 AM
Default bravo 1 or x drive
looking for an upper bravo1 or x and a lower.
tbrown15239 is offline
Old 06-24-2015 | 09:42 AM
I have a Bravo One HP for sale. It has 750 hrs on it. The thrust beaings we're replaced last season. Everything else is original. Works great! Looking to unload it!
John
25AT500EFI is offline
Old 07-02-2015 | 01:43 PM
rslick's Avatar
What ratio are you looking for? A friend is selling a BravoX1.36 and a bravo 1.65.
rslick is offline
Old 07-02-2015 | 03:53 PM
What is the difference between Bravo 1 and Bravo HP?
GLENAMY 242SS is offline
Old 07-03-2015 | 09:47 AM
The gimbal has a bit more beef but still uses traditional sending units
airjunky is offline
Old 07-03-2015 | 10:45 AM
The OP was looking for a drive and somebody offer a Bravo HP, I had not heard of HP drive designation, Transom assembly yes.
Is there such animal as Bravo HP drive?
Old 07-04-2015 | 08:31 AM
I have a clean bravo 1 1.5 low water pickup drive,unit was torn down inspected and resealed by certified shop,ready to be installed it is older hp unit which merc heat treated the upper gears like the diesel units,I will take 2500 for the unit and can ship it in a merc box
MDGperformance is offline
Old 07-05-2015 | 08:17 AM
How could you tell if the gear set is the heat treated set? Dif part #, color, gear thickness?
Thank you.
Old 07-05-2015 | 08:56 AM
These gears were offered by merc in the mid 90s,these gears were the older style with the thinner floors ,it was mercs way to make them a little stronger,now all the replacement have the thicker floor and all the same,the old harden gears pretty much look the same so its hard to id them,the drives were labeled with a high performance sticker on them
Old 07-24-2015 | 11:39 AM
I have an XR lower off a 40 hr swept back
86 apache 22 is offline
