500efi intake gasket >
Old 06-11-2015 | 09:31 AM
Default 500efi intake gasket
Can I run a standard Felpro 1275 intake gasket on my 500efi or do I need to run the Felpro 17342 does anyone know the difference ?
jab052783 is offline
Old 06-11-2015 | 09:49 AM
F-2 Speedy's Avatar
I think I put the 17342 on mine, 26 bucks on ebay
F-2 Speedy is offline
Old 06-12-2015 | 10:24 AM
the 1275 has 6 bolt holes, the 17342 has 8 holes,either will work but with the 1275 you skip the 2 bolts on top .
mike tkach is offline
Old 06-12-2015 | 10:41 AM
1275 is for dart heads I believe, they dont have the "dip" between ports.
bigbird241 is offline
Old 06-12-2015 | 10:03 PM
dip between ports?if you mean the area near the xtra bolt holes that only the gm heads have that is because dart,afr brodix,etc only have 6 bolt holes.
Old 06-14-2015 | 04:15 PM
you really want the 1275S-3 cored and with print seal, does not have the middle holes. Your plain old 1275 tends to leak as it's not a cored gasket, only good for about a year, then comes the milk shake
tunertech is offline
Old 06-15-2015 | 07:38 AM
yep
