Question about B1 transom assemblies >
Old 06-12-2015 | 12:09 PM
Default Question about B1 transom assemblies
I hope this is the right place to post this....
What is the story when you look at a transom assembly and you see a plug has been put in near the top right side of a transom assembly - about 1" or so in dia.?
I know it is a method of fixing something that has wore out but I need this explained to me so I can understand what has been done, etc. Thanks!
eichhoma is offline
Old 06-12-2015 | 12:16 PM
It's Mercs way of accessing the bolt and nut needed to remove upper swivel shaft. Probably had gimble ring replaced or repaired.
1BIGJIM is offline
Old 06-12-2015 | 12:20 PM
So should a fella run away from transom assemblies that this has been done? do you have a ballpark idea what standard B1 transom assemblies that this has been do to are worth?
Thanks in advance!!
eichhoma is offline
Old 06-13-2015 | 01:50 AM
I would say it depends on who repaired them and how long ago. I wouldn't give more than about half the price of new.
New complete transom assemblies can be had for around $2200-2400.
Yours should be HP transom assemblies also.
This is the JRmarine way. http://www.jrmarine.com/instructions.htm
Merc has a kit as well
Griff is offline
