575sci what hyd rollercam to use >
Old 06-15-2015 | 05:16 PM
Default 575sci what hyd rollercam to use
Rebuilding engines taking out flat tappet cams and installing hyd roller cams..
So what should i use..Part numbers please...Crane?
tks chuck
chuckpp is offline
Old 06-15-2015 | 05:20 PM
Call www.potterperformance.com
Ron is one of the best with these Engines!
Unlimited39 is offline
Old 06-15-2015 | 05:35 PM
I'd check with Eddie Young. He knows these engines well. He's worth the call.
http://youngperformance.com/index.htm
MILD THUNDER is offline
Old 06-15-2015 | 05:50 PM
Not many top builders just going to give out their cam info....
Will depend a lot on what heads & the rest of the package, some cam specs might be good for one combo and not another
lsc86 is offline
Old 06-15-2015 | 06:30 PM
If i had 575's, this is the route I would go
http://www.dyersblowers.com/187/1676.html
Old 06-15-2015 | 09:06 PM
Eddie Young spec'd my cams and it chopped/idled and ran like a mofo. He sent my blowers off to DMPE also. Worth every penny.
keegan is offline
Old 06-16-2015 | 09:19 AM
Same here. Call Eddie Young
snapmorgan is offline
Old 06-16-2015 | 10:06 AM
1 MAIDEN AMERICA's Avatar
I used a Crane 16HR00110. .030 pistons, Super Chiller w/3.5" pulley, stock computer. 700+ tq from 3200-4900RPM, 600+ hp from 4400 RPM, max 698.9HP and climbing @ 5450 and the limiter kicked in. Couple hundred hours on them now.
1 MAIDEN AMERICA is offline
Old 06-16-2015 | 11:27 AM
How much spring pressure did you have also did you change the step studs for the rockers..?
chuckpp is offline
Old 06-16-2015 | 12:42 PM
Same here. Sounds really good and runs even better! He did a custom grind on mine - assuming others were same.
ALL_IN! is offline
